factory radio
Old Jul 18, 2009 | 05:32 PM
jpravi8tor's Avatar
Default factory radio
Need advice for removing the faceplate on the facory radio. I would like to check the antennae connection, It seems to improve when I hit a bump then go away at the next bump. Any advice is appreciated.
Old Jul 24, 2009 | 01:27 AM
Titan Joe's Avatar
I had mine out at one point. That wad back in high school. If I remember correctly, on my car (it may be different), there were tabs that lock the sides in. I had to work a screw driver in the side to get the tabs to release. I had to be pretty careful. Once I had it out, I may have found that there was an easier way, but that's all I remember.
Old Jul 24, 2009 | 04:05 PM
soundmiami's Avatar
What year/model ? Wagons have antenna booster amp which can get squirrelly
They all had spring tabs on the side, some are easier than others,
http://farm3.static.flickr.com/2643/...46a42f28a3.jpg
Old Jul 26, 2009 | 09:37 PM
jpravi8tor's Avatar
92 240 factory everything...do I have to depress the metal tabs on top as well? Great pic!! it allways helps when you can see what its supposed to look like!!
Old Jul 26, 2009 | 10:41 PM
Titan Joe's Avatar
I don't remember messing with anything on top so I don't think they catch on a lip. I think that they just hold it in tight. The radio kinda sits in it's own little plastic box.
mstrplmber
Jul 23, 2008 02:00 AM
volksnut
Jun 8, 2007 05:01 PM
rgs4x
Mar 27, 2007 02:13 PM
ko_kidd
Sep 8, 2006 12:03 PM
