FOUND a piece of the fuel relay ON THE FLOOR. Help!
Old Sep 14, 2012 | 01:57 PM
fwest's Avatar
Default FOUND a piece of the fuel relay ON THE FLOOR. Help!
Hi All,
So I've been having some stalling issues recently, and just ordered a new fuel pump relay to hopefully put an end to these intermittent, but annoying stalls.
I have ordered the correct part after researching online, and can even see where the old on is (right under the glove box). As I went to replace it today, though, I noticed a similar looking white box to the fuel relay pump I ordered loose, and under the seat!
I have no idea how this happened, or where this part even came from, but it's slightly smaller than the part I am replacing, but looks very similar. After running the part number written on it (1324675), I see that it is indeed part of the fuel pump relay. No idea how or why it became dislodged, but in the interest of just moving forward, I would like your help in figuring out where to plug it back in.
Anyone familiar with the points of access for the fuel pump relay pieces? Where should I even begin looking to plug this thing back in?
Thanks so much for the help with this bizarre situation...
Old Sep 14, 2012 | 07:16 PM
um, what year/model car is this?
the fuel pump relay isn't meant to come apart, but it has a base with the pins that go into the socket, a plastic 'box' shaped cover, and inside, there's a little circuit board, and two actual relays (seperate coils and contacts).
on a 740/940, the relays are plugged into a central panel behind the ashtray and under the stereo. on a 240, the relays are scattered about, I believe the fuel pump relay is behind/under the glovebox.
Old Sep 14, 2012 | 07:19 PM
oh, reading your message again, and between the lines, its obvious you have a 240
that relay shell under the seat might be detrius left behind from someone tryng to hack an old relay to solve a non-start problem.
Old Sep 14, 2012 | 07:20 PM
fwest's Avatar
Yikes, that was dumb. It's a 91 240 wagon... and yes the fuel relay system as I thought I knew it is located under the glove box. But apparently there are multiple pieces to it, and from poking around a little more, it seems like this smaller piece came from a connection under the steering wheel...
Old Sep 14, 2012 | 09:33 PM
over by the steering wheel, that would probably be some different relay.
240 relays are pretty scattered. when I looked up that 1324675 PN, it wasn't the fuel injection/pump relay, it was something else unspecified.
ahhh, I did a part number search in Vadis. Relay PN 1324675 is for the electric rear window heater.
Old Sep 15, 2012 | 05:29 PM
dug up my 1991 240 'greenbook'. the relay behind the glovebox is in fact the LH2.4 'main' relay (which is fuel pump AND fuel injection, 2 relays in one can), and the rear window defroster timer relay is somewhere behind/under the instrument panel on teh driver side (drawing is quite vague)
Ahmed
Mar 16, 2014 10:59 PM
alkali2010
Mar 23, 2010 08:38 PM
Gary S
Jan 28, 2008 01:21 PM
kewlle
Jun 20, 2007 11:02 PM
