Fuel guage problem
Old Oct 28, 2007 | 01:39 PM
Sublime69's Avatar
Default Fuel guage problem
I have a 94 740 non turbo and the fuel guage is always on empty, any ideas what i can do to fix this?
Thanks
Old Oct 28, 2007 | 04:55 PM
Sublime69's Avatar
Default RE: Fuel guage problem
Sorry its a 94 940 not 740
Old Oct 29, 2007 | 09:31 PM
Sublime69's Avatar
no one has any idea what it could be?
Old Oct 29, 2007 | 10:42 PM
Kruspe31's Avatar
could be the float thats in the gas tank sending unit. The wiring from the instrument cluster check that first.
Old Oct 30, 2007 | 01:25 PM
Sublime69's Avatar
Ok ill try that, do you know how to get to the sending unit? do i have to drop the fuel tank? Or is there an access pannel? Thanks!
Old Oct 30, 2007 | 03:37 PM
Kruspe31's Avatar
I know on my 90 740 turbo you can access the module in the trunk
Old Oct 30, 2007 | 06:39 PM
tripleb's Avatar
Kind of crude, but you can smack on the top of the dashboard when everything is on and the gauge is reading low, and if the gauge starts working, then you know it's either the gauge/wiring/printed circuit board.
Otherwise you're looking at a sending unit. Kind of a pain on these cars, but you don't have to drop the tank. There is a 10" X 10" black cover in the trunk behind the back seat, under the carpeting.
Good Luck
B
Old Nov 1, 2007 | 08:09 PM
Sublime69's Avatar
i hit the dash today and the guage started to work untill i shut it off now i got nothing, even if i beat the dash! ha
Old Nov 1, 2007 | 08:44 PM
tripleb's Avatar
Did the gauge instantly start registering?
If so, it sounds like it's the gauge, wiring connector to the instrument cluster, or the "wiring plate", which is likle a printed circuit board.
Sounds like it's pretty consistent, if you pull the instrument cluster and leave it connected, you may be able to wiggle the connector and see if the connection is poor, or check voltage reading at the gauge to determine the faulty part.
I've had to diagnose at least 5 of these or so, and sometimes it all starts working when you take it apart, so it can be tough to diagnose. Hope you find the problem.
B
Old Nov 2, 2007 | 09:07 AM
Sublime69's Avatar
How do i go about pulling the cluster out?
TheVolvoMan
Jan 8, 2007 09:22 PM
GeoffC
Feb 13, 2006 11:33 PM
petes99xc
Dec 11, 2005 01:25 PM
rocknroll_1950
Dec 3, 2005 10:29 AM
alan3301
Jun 7, 2005 04:06 PM
