gauges don't work
Old Mar 10, 2006 | 11:23 AM
loadams's Avatar
Default gauges don't work
Hello all, just bought my 1st Volvo, 93 940 wagon. Just a quick question.............
I've checked the fuses and their good, but neither the fuel gauge nor the temp gauge work.
Picking up a manual this weekend, but any ideas on a quick solution?
Thanks plenty in advance.
Old Mar 10, 2006 | 08:54 PM
Default RE: gauges don't work
I would pull the cluster and check the Circuit Board on the back.
http://www.volvotechinfo.com/WD123/
Here is a link to a site that has wiring diagrams.
Old Mar 12, 2006 | 11:59 AM
loadams's Avatar
Thanks Tech for the valuable link.
Well, hit the interstate yesterday, fuel gauge started to work after a good bump in the road, temp gauge did not. Gonna check for loose wires, etc..
Again, thanks.
Old Mar 12, 2006 | 12:17 PM
Let me know how it goes.
Old Mar 14, 2006 | 02:18 PM
tkeser's Avatar
I had the same problem on my '86 240. Got a by pass wire which replaces temperature compensator board and also replaces voltage stabilizer, both located on the back of instrument cluster. Temp gage works fine, still no fuel, have to investigate sending unit on gas tank still. It took about an hour to pull cluster, make replacement and re-install.
Good luck.
Tom
crazypenguins
Jul 10, 2012 12:52 PM
Typhoon
Jul 11, 2010 10:18 AM
chadman551
Nov 9, 2009 11:16 AM
bli745
Oct 31, 2006 04:02 PM
ChrisKing
Mar 13, 2006 09:45 PM
