Good morning in need of help Volvo 240 will not run
Old Dec 1, 2015 | 07:34 AM
240fanatic's Avatar
Exclamation Good morning in need of help Volvo 240 will not run
I need help I bought a 1988 Volvo 240 wagon Dl automatic transmission. It was cranking fine before I had it towed to my house.now when I turn the key all it does is click no crank Could somebody please help??
The battery has power I'm really confused as to what it can be
Old Dec 1, 2015 | 12:59 PM
Random's Avatar
Could be a lot of things, solenoid, starter, PNP switch I would start with those three in that order.
Old Dec 4, 2015 | 05:05 PM
240fanatic's Avatar
Thanx! It was the pnp switch!!
Now I turned it on it ran 2/3 seconds than it suddenly shut off
All it does is turn over what can it be
I recently replaced both fuel pumps
Old Dec 4, 2015 | 06:15 PM
Random's Avatar
Check fuses/relays, does it throw out any error codes? I had a feeling it was the PNP switch, just wanted you to check the other two first and rule them out before replacing. Did you put in a new one? I pulled my old one and took it apart and cleaned it up although it was close to immaculate when I took it apart.
Old Dec 4, 2015 | 06:27 PM
240fanatic's Avatar
Default witch
Witch relay would it be? I checked the one by the glove compartment
And it clicks do I know it works
Old Dec 4, 2015 | 06:28 PM
240fanatic's Avatar
So I know it works
Old Dec 9, 2015 | 06:41 PM
Is the pumps running?
Old Dec 10, 2015 | 06:17 PM
relays can 'click' and still not work right, if there's too much crud on the contacts, or bad soldering on the little circuit board.
mphilleo
Dec 23, 2013 02:17 PM
djoker04
Jun 22, 2011 09:28 AM
prophet_of_profit
Jul 29, 2009 09:14 AM
Silver_Sixty
May 12, 2008 03:20 AM
