hard start
Old Feb 24, 2008 | 07:01 PM
cla6665's Avatar
Default hard start
Here's another one. I have a 1993 240 and for the past couple of days it doesn't start that easy when cold.
As soon it warms up it runs perfect, idles good. Turn it off and starts good again.
It seems like it doesn't like the cold. I got all new,distributor, rotor, wires, fuel pumps, injectors, ecc..
Any ideas?
Thanks all
This web site is great. I got a lot of help from you guys.
Thanks
Old Feb 24, 2008 | 11:30 PM
tedv's Avatar
Default RE: hard start
How about a battery?
Old Feb 25, 2008 | 02:51 PM
jonesg's Avatar
Pull the codes, see if its the coolant temp sensor,
if thats gone bad you won't get a signal to trigger the cold start injector,
hence hard cold starts.
I've had that problem and also when the injector relay was going bad it became increasingly hard to start, but ran once it got going. If you have 2 relays on the coolant bottle bracket just swap them and see if that fixes it.
It ought to show as a bad signal in the injector codes, but it doesn't say where.
Pull the codes anyway.
DecalService
Dec 4, 2019 10:52 PM
icthus
May 29, 2012 12:30 AM
daver80
Jul 13, 2009 10:19 PM
jerryman
May 23, 2006 01:19 AM
89lxjimmustang
Jun 28, 2004 05:23 PM
