help! spacers won't fit flush onto 1993 Volvo 240 hub
Old Jul 4, 2019 | 01:46 PM
avanti240's Avatar
Unhappy help! spacers won't fit flush onto 1993 Volvo 240 hub
Hello all!
I'm new to this forum, and new to any Volvo forum in general. I currently own a 1993 Volvo 240 wagon that I rescued from a junkyard when I was 15, and its been my daily driver ever since. I just recently purchased some IPD 25mm wheel spacers, SAE wheel nuts & the lot to install some 16" 850 steelies to the car, but I found that my hubs have a pair of small guide bolts on them. I had forgotten this detail when I had put 740 Hydra wheels on the car a year ago. Is it safe to remove these bolts to install the spacers to ensure that the spacers are flush with the hub? IPD mentions in the sales description for the spacers that they will fit any 200/700/900 series car, just that 200's with small brakes (which mine has) will need a SINGLE brake pin/bolt removed prior to installation. However, my car has two. Is there any safe way to go about this?
I can provide pictures of the hub and the spacers.
Thanks,
Jack
Old Jul 5, 2019 | 10:59 AM
act1292's Avatar
You can remove the alignment guides. They are there to retain the disk on the hub when the rim is removed and also act as a guide. You can remove them and it does not affect the safety of vehicle.
beleive
Mar 6, 2016 11:37 AM
xDread92x
May 15, 2013 06:07 AM
pdlarson
Oct 31, 2011 08:56 AM
93-245
May 4, 2010 11:45 PM
rcundall
Jan 4, 2009 05:40 PM
