How can I adjust front window glass in door frame?
'89 744
The driver's side front window has been tilted forward since I got the car many years ago, so when closed, there is a small gap at the top between the rear (vertical) door rail and the vertical edge of the glass. The glass is basically tilted so it's out of the rail from half-way up (the glass is tilted down at the front in its opening, though it goes up/down fine w/ the electric regulator).
This makes it noisy at 45mpg and above with wind noise w/ the window closed.
I finally took my door apart to investigate, and it appears there is no adjustment that would allow me to raise the front mounting connection between the regulator arm and the glass clamp. I was hoping there would be a slotted hole that would allow me to re-position the front arm-to-glass relationship, but no dice).
There is enough play in the system that I can raise the front so the window seals perfectly, but of course it just falls back down. Where that forward arm connects to the rear scissors arm, there is a "pivot" that is held together with a connection having a 1/4" square hole in it as if it could be turned (possibly an eccentric cam to allow relative adjustment to level the glass?), but it won't budge (and I don't dare apply enough force lest I damage something).
Nothing looks worn, so I can't believe it's worn and that Volvo built in NO adjustment for the window "angle."
Is there a way to alter the "angle" of the glass somewhere so the horizontal edges of glass are horizontal (level) so the window is "square" in it's frame??
I did a "Search" but alas saw no reference to any adjustments.
Bob
Bob
I am just surprised that it should have worn out by 80k miles when I got the car back in 2005 (I now have 113k on the car).
There is a tiny bit of play at the main pivot scissors (allowing the front of the window to be lifted maybe 1/2" independent of the back end of the window), but the tuning forks and everything else is tight-as-new. No other wear anywhere.
I was hoping the pivot point w/ the 1/4" square opening was an eccentric to adjust the front-to-rear window height.
Oh well.
Thanks,
Bob
Oh well.
Thanks,
Bob
OK, I GUESS I AM SUNK, THEN.
ODDLY, my nylon sliders ("tuning forks") have zero wear, or I'd switch them F to R as that would help when out the window a bit.
Unfortunately I am in the middle of a household move or I'd try cutting my front arm and mig welding it displaced a bit higher (or the rear one a bit lower by overlapping the sections a bit and welding). That butchery would be an ineligant solution, but cheap, and worth a try.
Thanks
Bob
Thanks
Bob
sedxsedx
08-20-2012 09:39 PM
