Hybrid Rex/bosch
Old Nov 21, 2018 | 09:16 PM
Goldenblock's Avatar
Default Hybrid Rex/bosch
Happy holidays Volvo heads!! Golden block here! Is there anyone on here who has a bosch/ regina hybrid car???
Meaning rex ignition mated with bosch fuel injection( pump under car) just curious...
mine is 1989 740 gl. Over 2 million miles strong now! 106 miles a gallon
Oss
Old Nov 22, 2018 | 12:55 AM
so does that have a side distributor or camshaft end? I do hope you meant to type 26 MPG, as I'm having issues believing 106.... Now, I had a 650cc motorcycle that got 80-100 if you were cruising smoothly.
Old Nov 22, 2018 | 02:48 AM
dytha99's Avatar
I don't own a "hybrid" but came across one in the junkyard years ago. I think it was a 90 or 91 740 wagon...Regina under the hood with a pump under the car and in the tank.
I remember because I bought both pumps. They looked brand new...the under the car pump has been on my 240 for a couple years and the in tank pump is still in my basement.
I kinda prefer the one pump Regina cars. Just one pump to worry about and no maf sensor.
Old Nov 22, 2018 | 01:05 PM
lev's Avatar
lev
I have seen Regina cars with two pumps, that doesn't make them anything except Regina cars with two pumps. As far as the rest, yeah, right!
Old Nov 22, 2018 | 01:24 PM
yeah, the single regina and (non-turbo) dual bosch FI pumps are pretty much interchangable as both systems need the same feed pressure and volume. In fact, later Bosch systems, like used on the 850, were a single in-tank pump, and you could probably use a 850 pump on a 240/740/940 except you'd need to adapt the tank pump/fuelsender assembly as they are probably a different size. an 850 T5 turbo pump would likely work with a lh2.4 turbo 940, too, as they require similar pressure and volumes.
Old Nov 22, 2018 | 01:30 PM
a footnote, my mercedes 300E/E320's use NO tank pump, they just have an under-the-back-seat pump... except Mercedes uses two pumps in parallel, I think for reliability (car still runs 100% with only one).
david12345
Aug 17, 2015 08:49 PM
volvo745newbie
Jul 14, 2015 06:11 PM
floz313
Oct 20, 2013 04:36 PM
92_240_sedan
Jan 14, 2013 07:31 PM
volvogal2
Jun 12, 2011 07:42 PM
