idle air control valve question, and replacing vacuum lines
Old May 25, 2019 | 08:41 PM
kcteun's Avatar
Default idle air control valve question, and replacing vacuum lines
I tracked down a surging idle to a frozen iacv. It looks like a new oem unit is well over $100. A generic part is $31. Does anyone have experience with the generic? I learned years ago that some parts (MAF and others) need to be oem.
AND
I'm planning on replacing all the rubber vacuum lines with silicone. Has anyone seen an accurate diagram of vacuum hose routing?
1984 245 base model with M46
Old May 25, 2019 | 09:00 PM
lev's Avatar
lev
Can you unfreeze the valve? Better than the cheap one... I personally don't have any experience with that valve aftermarket but generally with electrical parts it's better to avoid.
The hose diagram is a simple one for that car, why don't just replace them one by one? Otherwise the Volvo Green Book should be consulted.
Old May 25, 2019 | 11:26 PM
kcteun's Avatar
Hoses: not sure what's original, would like to do it back to "stock".
Tried unsticking it with solvents and lubes. No joy. Makes a "click" noise but no movement. They don't open for servicing. There are junkyard parts available, if the aftermarket piece is crap, I guess I'll get a used one and clean/lube it well.
Old May 26, 2019 | 02:12 AM
dytha99's Avatar
When I replaced the vacuum lines on my '89 740 I just this link as a reference...
https://www.brickboard.com/FAQ/700-9...oseReplacement
and I used 3.5 mm ID hose...they make for a tight fit at that size.
Johnnysaltshaker
Oct 16, 2015 01:22 AM
Jabdoney
Oct 15, 2015 09:57 PM
one to remember
Aug 24, 2015 08:54 AM
pierce
Aug 22, 2014 03:45 PM
apfurste
Jun 26, 2009 08:02 PM
