Instrument cluster compatability
Old Nov 21, 2013 | 01:52 PM
Shaggin240wagon's Avatar
Default Instrument cluster compatability
Just bought a new instrument cluster for my 240 wagon. I have a 91 and I got a cluster from an 89. It doesnt have an ABS light on the new cluster or an airbag. Will this effect my ABS brakes or my airbags in any way other then not having the warning lights? I would have swapped just the speedos but my old cluster is fried. Also the check engine light is in a different slot..will that still function?
Old Nov 21, 2013 | 06:04 PM
not sure the wiring is 100% compatible between those years. would probably require studying the greenbooks for both years and noting any differences in the instrument panel connections.
Old Nov 21, 2013 | 06:51 PM
The only wire that did not plug in was the pink and white wire that I am assuming is abs related. All of my gauges work fine. The cruise control seems to make a noise when engaged. Been trying to get my dash in proper working order for two months..
Old Nov 21, 2013 | 06:55 PM
the red/white wire on a 240 instrument panel is the optional tachometer, and plugging it into the wrong place fries stuff.
Old Nov 21, 2013 | 07:09 PM
I learned that the hard way. There is a pink wire also.
Old Nov 22, 2013 | 05:51 AM
act1292's Avatar
If your car has ABS and you didn't swap the speedo board from your old cluster, I would expect that your speedometer would read incorrect speed as the ABS cars had a different tone ring in the differential than non-ABS cars ('89 did not have ABS). Actually, the connector to the speedometer has different number of wires for non-ABS vs. ABS.
Other than the speedometer circuit board, I think the main circuit board is compatible but I can't be completely sure. If your cruise control is working, I don't think the extra noise is due to the cluster swap.
Old Nov 22, 2013 | 10:03 AM
lev's Avatar
lev
You can test the ABS easy enough whether it is working or not--it should be OK. The SRS, hard to test. At any rate you won't know if these systems are working properly without the lights--they are both computerized and the lights are a part of the circuit. Diagnostic checks will show faults. You can probably adopt the board to function but it will take some fiddling...
volvo5volvo
May 29, 2012 05:46 AM
autobeef
Oct 17, 2007 12:00 PM
Justin325
Jul 4, 2006 12:17 AM
cool_kyle_3000
Mar 5, 2006 11:29 PM
oalsa
Nov 16, 2005 11:12 PM
