intermittent dying problem 92 240
Old Sep 17, 2008 | 02:07 PM
harebearva's Avatar
Default intermittent dying problem 92 240
Hi all. I have had a recent problem with my 92 240. It usually start and idle ok, but within a mile, if I stop and let it idle, it will lope once or twice then die. It starts easily after this happens, but only if I keep a lite foot on the gas pedal. It did this for a day and then suddenly, the problem went away. I was messing around under the hood today, and found that while it's idling, if I lift ( pardon my terminology, i'm a semi-retard under the hood ) on the accordian hose coming out of the air filter housing, the engine will begin to do that loping again, although not bad enough to make it die. I was lifting behind what I think is the MAF sensor, but I'm not sure. Air leak, you think?
Old Sep 17, 2008 | 03:19 PM
blue goose's Avatar
Default RE: intermittent dying problem 92 240
I would remove the accordion hose and check it for a leak. Or just replace the hose.
Old Sep 17, 2008 | 04:42 PM
wojeepster's Avatar
Accordian hose sometime rubs against fender and gets hole. You can temporarily fix with electrical tape..
peerson89
1998-2000 model year V70
Sep 24, 2014 08:59 PM
NAS
Dec 4, 2010 09:43 PM
NAS
Dec 1, 2010 02:14 PM
kottre
Jul 25, 2005 09:38 PM
