kit to attach hood (bonnet) release cable to handle
Old Aug 19, 2019 | 09:53 AM
Malbone's Avatar
Default kit to attach hood (bonnet) release cable to handle
My 240's hood release cable snapped just at the handle. The cable is (was) attached to the handle by a cylindrical barrel nipple that was an integral part of the cable.
I fear that replacing the whole cable will involve my mechanic in a few hours' work. Amazon and other retailers sell cable repair kits that are mostly for motorcycle throttle or brake cables. Has anyone ever tried using these? Most importantly, does anyone know the dimensions of the barrel nipple and whether it can be extricated from the handle?
Old Aug 19, 2019 | 11:00 AM
I'd replace the cable. the hardest part will be opening the hood with the broken cable, if you can get that done (maybe vice grips on the exposed end?), then its pretty easy. grease the new cable as its going in the casing, grease the latch mechanism.
Old Aug 19, 2019 | 09:37 PM
Malbone's Avatar
Thankfully there is plenty of cable exposed, so I could get a vise grip on it if necessary, but I'm hoping not to have to run a new cable through the firewall, which I understand is a hard job. I'm looking for a hack so I can reattach the cable to the handle -- or, if that can't be done, attaching it to a new handle or a rope loop. There are kits on the market to replace the handle on Hondas, which have a somewhat different handle mechanism; the replacement fastens onto the cable with a couple of set screws. I can see the barrel that used to hold the cable to the red handle; I'd like to be able to remove it, attach the cable to a new barrel, and put it back into the handle. Maybe that's just impossible?
Alternatively, has anyone run a bungee cord from the hood latch to a convenient spot on the front of the car?
Old Aug 19, 2019 | 09:43 PM
drill the hood, and install racing pins,and remove the 'tongue' that fits into the latch ?
Old Aug 21, 2019 | 09:02 PM
Malbone's Avatar
It's not exactly what I was looking for, but for those that want to replace the entire hood release cable, there's a YouTube video showing how it's done on a 240:
Old Aug 21, 2019 | 09:06 PM
Malbone's Avatar
Since my cable broke right at the handle, my current idea is to loop the exposed cable through a double-barrel ferrule (also called a swage) and crimp it closed. That will shorten it by an inch or two, so I'll have to figure out how to attach it to the handle (or perhaps just encase it in plastic tubing so it can be pulled directly). I'll take a closer look this weekend.
Old Aug 27, 2019 | 07:45 PM
Gilligan's Avatar
Is there a video on how to replace the hood release cable on a 2014 S60?
Old Aug 27, 2019 | 08:11 PM
you probably should ask the S60 section, this is the 240/740/940 section for the 4 cyl RWD volvos of the 80s, early 90s.
BPATR1CK
1998-2000 model year V70
Aug 28, 2012 06:09 AM
JohnAlden
Sep 5, 2011 08:03 AM
87westy
Apr 12, 2011 10:04 AM
ImaNoob
Jan 4, 2010 05:11 AM
skooter66
Oct 24, 2009 09:42 AM
