Lambdasond question
Old Jan 18, 2011 | 08:34 PM
cg23cpo's Avatar
Question Lambdasond question
I have a '94 940 wagon with Regina and distributor in the block. I trying to determine if it is supposed to have an O2 sensor. Per FCP (and other exhaust pipe suppliers), Chilton's and Haynes: some do and some don't. Something blew out of the exhaust pipe just in front of the cat. converter and left a hole (no threads left to screw anything into), but I don't see any wires dangling to indicate the O2 sensor was blown out and ripped off the wires. So, I'm thinking there was no O2 sensor but rather that a plug was in there.
Any ideas? I plan on replacing the pipe and maybe the cat. converter (202K miles) when the weather breaks in the spring (upstate NY)
Front suspension, oil pan, battery, plugs and wires, throttle body cleaned and front engine seals have been replaced, now I'm working on drivability issues. Last check of codes indicate coolant temp sensor no reporting to control unit and it was running rich.
Also looking for a vacuum fitting for the intake manifold to attach vacuum gauge to.
Old Jan 18, 2011 | 09:53 PM
lev's Avatar
lev
Hm, pretty sure that all have O2 sensors. Bosch and Regina use different sensors, not interchangeable, but both systems have them in '94.
Old Jan 22, 2011 | 07:57 PM
cg23cpo's Avatar
So does anyone have an actual pic of the location? Everything I see in the publications is kind of vague. I need a better reference.
Thanks
Old Jan 22, 2011 | 08:56 PM
jagtoes's Avatar
Thanks
Follow the exhaust pipe down from the engine to the cat. and you should see it mounted before or in the catalytic converter. On some exhaust systems they have an extra hole location but it would have a threaded plug in it. If you blew that off you would have a loud exhaust noise. You may have too replace that pipe or get the hole welded up.
Old Aug 17, 2012 | 06:27 PM
cg23cpo's Avatar
Thanks everyone. I found the O2 sensor on the inboard side of the cat. and patched the hole with some galv tubing and hose clamps. On the cheap as I'm selling the car or waiting until my 17 yr old really needs it.
Old Aug 17, 2012 | 10:43 PM
without the O2 sensor in place, the Check Engine light will come on in short order, and the car likely will run rich and burn excess gas. any jurisdiction that has ANY sort of vehicle inspection will fail the car on that.
96850urbo
Jan 23, 2009 01:00 PM
Adrenalin540
Dec 31, 2008 10:19 AM
Aaronius
May 30, 2008 06:10 PM
pvolvoman
Oct 24, 2007 07:29 PM
mordezmoncou
Apr 9, 2007 05:22 AM
