left blinkers dead after doing other work on car
Old Jan 21, 2020 | 07:21 PM
volvodriver99's Avatar
Default left blinkers dead after doing other work on car
So I'm about halfway through doing a blower motor and blower motor resistor swap out on my 1986 Volvo 240 DL and before putting everything back together completely I went to test everything and now I'm noticing my left blinkers are just totally dead. This is not a bulb issue, as the front and back and the indicator inside the car just do nothing now. The right blinker works just fine.
Any idea what I can check to see where it might be disconnected? I'm thinking it's gotta be in that mess of wires that connected above and around the steering column but I made sure they were all fully connected before putting the casing back on it so I'm not so sure.
Old Jan 21, 2020 | 09:09 PM
does the emergency blinker circult work ? the diagram doesn't show where the turn signal blinker relay is grounded, but I bet its right near the relay, which is right near where those door lock relays are. it too is a black ground wire.
Old Jan 21, 2020 | 09:16 PM
I have to check the hazards tomorrow. I thought of that myself earlier and am not sure if they completely work, partially work, or not at all.
I definitely have all of the original grounds attached back to their original screw. There were four there initially and there are four there now.
Old Jan 22, 2020 | 01:44 PM
The hazards fully work with the left and right blinkers working in the front and back.
Old Jan 22, 2020 | 04:09 PM
So this issue was caused by a disconnected wire on the steering column. It's fixed now.
marvgt95
Aug 30, 2024 01:18 PM
Alexis Covarrubias
Apr 18, 2019 12:34 PM
shur
Feb 1, 2015 07:52 AM
Dan Kooda
Nov 21, 2013 04:10 PM
grigalid
Sep 16, 2010 11:26 PM
