Left Rear taillights malfunctioning 88 240
Old Nov 3, 2011 | 08:14 PM
n00bkilla2k's Avatar
Default Left Rear taillights malfunctioning 88 240
The left rear taillights aren't working on my 240. I tested the bulbs in the sockets on the right and they worked fine, the fuse is fine as well. The brake lights work fine, as well as the blinker, and the reverse light, just the two taillights don't work. Any ideas?
Old Nov 3, 2011 | 10:00 PM
swiftjustice44's Avatar
Sedan or wagon?
Old Nov 4, 2011 | 02:45 AM
Default Sedan
Sedan
Old Nov 4, 2011 | 06:09 AM
The parking lights are fused left and right side. Means if the entire circuit is blown you won't have the front parking light either...so that's something to check as is physically twisting the fuse in its holder to clean it off. Obviously, if the front light is burning on that side. it isn't the fuse. What I'm not reading is ...have you checked the circuit for current? I'm guessing tools are limited? You can make a test light out of a tail light bulb, 2 pieces of wire and some duct tape.
Old Nov 9, 2011 | 04:27 PM
dezertsub's Avatar
How the hell do I explain this...
You know that green plastic sheet that looks like something outta TRON, that your bulb housings connect with to give the bulbs current?
Take the bulb housing off, and get a clean pencil eraser...clean the metal where it touches the TRON plastic, and rub where that housing makes contact on the sheet.
Hope that makes enough sense.
martino89
Jan 4, 2013 01:33 AM
irpple
Dec 13, 2012 12:22 AM
delfino26
Jun 17, 2011 08:44 PM
Rodsglt
Dec 6, 2006 01:31 PM
VolvoJimmy960
Jan 19, 2005 09:38 AM
