Need AC help in Dallas!
Old Jun 19, 2020 | 01:30 AM
stephlopez53's Avatar
Default Need AC help in Dallas!
Hello everyone!
I desperately need some help with my AC. I had the radiator replaced a few months ago and the wagon has been running fine, but now that summer is just about here, the AC isn’t blowing cold. I’d like to see what the issue could be, or if anyone has advice on where to begin, any help is appreciated.
thanks!!
stephanie
Old Jun 19, 2020 | 05:26 PM
can you feel/hear/see the compressor kick on when you turn the AC on REC and the coldest setting? I'd suspect that when the radiator was worked on they may have damaged one of the lines to/from the condensor or the condensor itself and your system lost its charge. If there's no freon in the system the low pressure sensor will keep the compressor from coming on. You'd need to have a pro shop inspect for physical damage then measure the system pressure. If its low, they will recharge the system with some dye to find where its leaking out then repair, reseal, vaccuum out and recharge the system.
Old Jun 20, 2020 | 09:59 AM
lev's Avatar
lev
Was your A/C working BEFORE the radiator change?
If so, yes, there is a good chance that something got screwed up when the radiator was changed.
If no, or unsure, then there are many possibilities as to why it's inop now.
Also, please provide make, year, model, miles, etc, it really makes a difference...
daver80
Apr 30, 2012 08:20 AM
VOLVASTIC
Mar 5, 2012 11:02 AM
bizzy102
Feb 24, 2012 10:18 PM
akmwilliams
Sep 15, 2009 10:07 PM
NoleWithAVolvo
May 15, 2007 06:25 PM
