need help
Old Aug 29, 2017 | 10:05 PM
pickel rick's Avatar
Default need help
so I found a garrett turbo from pick n pull and new exhaust manifold for my 93 940 wagon. picked it up for 100 bucks but now that i have replaced that and my breather box the car now goes up to about 3000 and acts like it's redlining, I let off the gas and it kills itself. I put a new exhaust manifold gasket and new lines for the turbo. idk wtf the problem is.
all work I've done-
- "new"turbo/ exhaust manifold.
- new exhaust manifold gasket
- new breather box ( oil trap )
- new starter
- new plugs cap and rotor
- new Air Intake Tube Mass Sensor to Turbocharger
- new intake manifold gasket
- new valve cover gasket
- had a new water pump when bought( less then 5000 miles on it )
- timing belt was done 12,000 miles ago
the car never had a problem till I put this new turbo on the last one feel apart. idk what else to do some advice would be amazing if some one can help
Old Sep 2, 2017 | 09:47 PM
lev's Avatar
lev
It's hard to deal with this kind problem on a forum, i.e. without laying of hands. This kind of massive part swap always poses the question, were all parts good/functional? Were all parts installed correctly? It's better to change one thing at the time, see how it affected the car's condition. All I can add is to help is to advise you to recheck your work, verify that what could be causing the problem is double checked.
Old Sep 10, 2017 | 08:00 PM
indeed, its always best to start with the last thing you did before it went sideways.
IIRC, 93's came with Mitsubishi TD04 turbos, not garrets.
andrei3333
Dec 26, 2010 10:22 AM
Sanel30
Feb 18, 2010 09:16 PM
texan_176
Oct 4, 2009 10:05 PM
chef
May 19, 2009 05:57 AM
Svtfiveoh
Apr 15, 2008 06:51 PM
