Need a no-start troubleshooting checklist
Old Apr 16, 2018 | 01:16 PM
  #21
both pumps should run for about 1 second when you switch the key on, then it stops until the motor turns over (as detected by the crank position sensor aka CPS). When the motor stops turning over, again it stops the pump about 1 second later.
Old Apr 16, 2018 | 01:45 PM
  #22
if neither pump is running, it just might be your fuel pump relay, that would be simple
some late 940s' have a different setup with two separate relays..
all LH 2.2/2.4 740/940's up to 1993 used a single large relay module that had two relays inside it, in position "E" in the relay panel (middle row, left-most relay as you face forward). this double relay, one half is the power for the ECU and stuff, and the other half provides the power for the fuel pumps. on these cars, there is an additional relay under the hood called the 'radio suppression relay' which powers the fuel injectors.
on many 1994+ cars, they got rid of the dual relay, and went to a single relay in position "M" for the fuel pumps, and rewired the 'radio suppression relay' to power the ECU as well as the injectors. that single relay is the same part number as the blue fog lamp relay in position "F", so you can swap those (assuming you have fogs) to test it.
stevetro1
May 28, 2013 09:01 PM
radio16
Oct 12, 2011 09:35 PM
Tyler 99 S70
May 17, 2011 12:33 PM
Aftermidnight
May 1, 2011 12:47 PM
fidelissemper
Aug 3, 2010 01:20 AM
