New Owner with a few questions
Old Mar 30, 2010 | 08:01 PM
frogprince's Avatar
Default New Owner with a few questions
Hello,
I just purchased my first Volvo last night and got her home and have a few small problems to get sorted out.
She is a 1985 Volvo that was imported from Belgium (What I have been told). She was still running on a carb stock from the factory and has been converted to run on either CNG or LPG (currently on LPG). She runs great and has been on this fuel for several years now.
The problem that I am having is that she is really sloppy on shifting. The five speed transmission works great other than you have to "hunt" for the gears. First for example you have to lift slightly op on the lock out for reverse to get into 1st gear. Then going between gears it can be a hit or a miss to get them on the first attempt. Is this the shifter itself or is this the linkage? Or even the clutch cable?
I believe that to be the only real issue at the moment. Any help would be appreciated.
Old Apr 1, 2010 | 10:14 PM
frogprince's Avatar
Hello,
Does anyone have any ideas on what could cause the shifter to feel loose and sloppy?
Also when your altenator starts going out does the idiot light start flickering on and off randomly. My started that today after taking her out finally. Just get her tagged and insured and cant wait to start driving her on monday to work.
Old Apr 2, 2010 | 12:54 AM
TIPSP's Avatar
Got Boost?
hows the oil level? the cable might need adjusting.
Wait for the experts to get on.
Old Apr 2, 2010 | 03:02 AM
Typhoon's Avatar
You say 5 speed transmission? Is it a manual 4 speed with the overdrive button? If so, the shifter sits in a big nylon bushing assembly that's known to disintegrate with age, replacing it is a cheap, easy fix that will really improve things.
Regards, Andrew.
Old Apr 2, 2010 | 10:01 AM
frogprince's Avatar
Morning,
The transmission is not the 4 speed with the overdrive. The transmission is rather the newer 5 gear style with reverse to the left and the 5th gear off to the right.
Is this bushing part of the shifter or a standalone piece?
Thanks
Old Apr 2, 2010 | 10:45 AM
bubba240's Avatar
Yes the battery light flickering is a sign of charging problems ... usually a loose connection at the alternator.
Old Apr 2, 2010 | 12:50 PM
frogprince's Avatar
Hello,
Yep the battery was slight loose and the light went away and the altenator checked out fine. Though I didnt read the light right and it was another one that is flickering on and off. Cant figure out what it is. It look something like |0| with a line thru the 0. Any ideas?
Old Apr 2, 2010 | 04:47 PM
frogprince's Avatar
Never mind on the light. I discovered that this vehicle still has a choke on it due to when it was imported. It is not hooked up but on occasion it light comes just to mess with me I guess.
Old Apr 4, 2010 | 12:27 AM
frogprince's Avatar
Hello,
New problem. Since this car has been imported from Belgium to the US I ran into a problem with the blower motor. I recently picked up a replacement from the local auto store and it doesnt match the unit in the car. I investigated further and found out that they used a specific heater unit overseas. Any ideas on how to replace the blown motor for the fan?
Black850T5R
Jan 10, 2012 09:15 AM
V70 AWD Guy
Aug 5, 2011 11:41 PM
Artunc
Aug 29, 2010 06:27 PM
intrepidtek
Mar 31, 2009 10:45 PM
StuffSquared
Apr 4, 2007 03:32 PM
