No start. no fuel in my injectors... 91 240
Old Dec 1, 2021 | 05:14 PM
brick obsession's Avatar
Default No start. no fuel in my injectors... 91 240
Car died after idling about 1 minute. Cranks over but won't start tried messing with mass air meter, using starter fluid and replaced fuel pump relay. I just tested the second fuel pump under the car with a 12v and it worked but the wires connected to it don't appear to be live after using test light. All fuses are good I'm not sure what the problem is seems to be electric. New to car repair so any advice helps. Thanks!
Old Dec 1, 2021 | 05:21 PM
Originally Posted by brick obsession
Car died after idling about 1 minute ----. using starter fluid
If you spray starting fluid into the intake then spin the engine over and it does not fire - you have no spark. Have you checked for spark?
Old Dec 1, 2021 | 05:24 PM
I haven't. Can you lose spark plugs that quick? I drove it to the store then when I started it back up it stalled and wouldn't start. Also I have no fuel in my lines going to the injection rail that's what made me assume it was a fuel issue not a spark issue
Old Dec 1, 2021 | 05:35 PM
Sure they could be interconnected - but no spark = no explosions with starting fluid. That will eliminate guessing the fuel pump/s are bad. (because something is not turning on the iginition system and maybe not the fuel system.
a 1991 - does that car have the 25amp blade style fuse (for the fuel injection) mounted near the battery? that melts or gets a poor connection?
All fuses in fusebox have a good connection - sometimes they melt on the ends and looks good but are not.
Wiggled the connector for the ignition amp (if applicable , sorry it's been just a few years)
engine speed sensor wiring looks good? Insulation not shredded?
Old Dec 1, 2021 | 05:50 PM
Spare shaped fuse none apear to be blown or melted
volvy
Jun 24, 2012 11:27 PM
Lectrol
May 14, 2012 03:01 AM
89volvo240dl
Feb 8, 2008 05:20 PM
dstinsman
Jan 13, 2008 10:59 AM
