Odometer repair problem
Old Oct 17, 2008 | 09:19 AM
ron747's Avatar
Default Odometer repair problem
I have a 97 T5 with a broken odometer. I ordered the gear, removed the
cluster, removed the 9 screws, and now can not get the front cover separated from the the main unit (with gauges). The unit shown on the FCP Groton site is not a turbo. Anyone else had this problem and what did you do?
Old Oct 17, 2008 | 09:27 AM
Default RE: Odometer repair problem
You have to remove the nut that screws onto where the turbo guage hose was. Then it should slide off.
Old Oct 17, 2008 | 09:36 AM
ron747's Avatar
It's not the gauge plate I'm having trouble with, I haven't got that far, but the front bezel frame which includes the plastic lens.
Old Oct 17, 2008 | 09:43 AM
I always remove that last.
I remove all the screws holding the black plastic cover on and remove that.
Then remove the circuit board then the rest will come apart.
Old Oct 17, 2008 | 01:12 PM
ron747's Avatar
I goofed, didn't follow instructions correctly. I have the gear replaced now and preparing to replace unit in car. Thanks for your suggestions.
Old Oct 17, 2008 | 01:16 PM
If you go and drive it and it either doesn't work or you get about 1 mile and it stops then stop the car and push the reset button a couple of times then start driving again.
Shaggin240wagon
Oct 16, 2013 12:04 AM
rbrunn
Apr 22, 2011 06:18 PM
dgjohns
Dec 8, 2009 07:01 AM
Sambar Stag
Aug 30, 2009 07:43 AM
montysano
Apr 5, 2008 10:12 AM
