excessive engine cranking
Old Jun 10, 2014 | 08:41 PM
HECTORPORTALUPPI's Avatar
Default excessive engine cranking
hi!
I have 1994 Volvo 940 turbo wagon and it cranks the engine excessively before it starts.
in the morning, it starts right up, but after I stop the car for about one hour, it is hard to start and it drains the battery.
does any one knows how to fix this?
thank you.
hector.
Old Jun 10, 2014 | 10:39 PM
lev's Avatar
lev
Hard cold start: Coolant Temp Sensor--most likely reason.
Old Jun 10, 2014 | 10:59 PM
modifierwong's Avatar
Lev,
I've heard this suggestion a lot for hard cranking issues. Why exactly would this cause hard starting issues?
I personally found that vacuum leaks were my issue, especially in places where you don't expect. My 940 used to take a while to start, but I put a clamp on the hoses coming from the engine to the oil separator box and flame trap. Its been great ever since.
Old Jun 11, 2014 | 02:48 AM
drew84's Avatar
Hi, Have s40 1.9l which had the same problem, i replaced the fuel regulator and it fixed it, starts frist go. Easy to do!
Old Jun 11, 2014 | 02:59 AM
an S40 is a completely different car with a completely different engine and fuel injection system
it would be smart to test the fuel pressure, however. if its off, then your fuel pressure regulator is suspect.
Old Jun 12, 2014 | 12:09 AM
lev's Avatar
lev
Mod...wong, the reason the coolant sensor is often at fault for cold hard start is that the computer should signal for extra fuel in cold engine to get it started. If no such signal is coming, due to a bad sensor, computer does not send this extra fuel and it takes longer for enough fuel to trickle down and affect ignition.
Old Jun 12, 2014 | 07:21 AM
act1292's Avatar
If I read the post correctly, he is having trouble with warm starts. Cold starts are fine. For warm start issue, I would suspect the fuel pressure regulator. But as Pierce stated, check the fuel pressure.
Old Jun 12, 2014 | 09:31 AM
lev's Avatar
lev
Yes, the FPR is a good candidate for warm starts trouble. I was answering the Modifierwong's question re CTS in geneneral...
maydayvolvo
May 19, 2009 03:56 PM
m2point1
Jun 1, 2008 11:54 AM
turbo940
Mar 29, 2008 07:18 PM
ccslaxer44
Jul 12, 2007 04:24 PM
Natalie
Jan 14, 2006 11:53 PM
