Oil Leak in '94 940
Old Dec 9, 2009 | 06:19 PM
eddieverity's Avatar
Default Oil Leak in '94 940
Hello,
Just recently bought '94 940 with 87k miles. There was a large amount of oil blasting past the oil filler cap. Was guessing it was just the cap as the rubber gasket was cracked. Replaced cap today & still getting small amount of oil leaking when engine rpms kick up.
Any idea as to what's causing the leak?
Old Dec 9, 2009 | 10:26 PM
john1990's Avatar
you shouldn't have oil coming out the hole even if the cap is off, I believe the term is blow by. it has to do with the valves and rings. go to the tech part of the forum. good luck
Old Dec 9, 2009 | 11:37 PM
tedv's Avatar
You should change/clean the flame trap/oil separator located on the left side under the intake manifold, between the 3rd and 4th runner, If they are plugged you'll have excessive pressure causing oil leaks.
ROBLU540
Feb 20, 2009 07:59 PM
Dobbersky
Apr 17, 2008 09:51 PM
DJboozeAlot
Nov 27, 2006 08:57 PM
GaryBrad
Aug 12, 2005 12:48 AM
GaryBrad
Jun 13, 2005 12:10 AM
