Oil Trap seperated / broke in half
Old Aug 10, 2014 | 01:26 PM
guest01's Avatar
Default Oil Trap seperated / broke in half
88 740T
Been dealing with oil leaks. replaced the turbo drain o-ring and gasket, oil pan, did all seals; cam, crank, and intermediate shaft, when I did the timing belt when I first bought it.
Did the oil trap about a year ago. noticed a bit of oil in the vicinity. started pulling oil trap to reseal where it connects to the base and when I grabbed it separated on me. Completely broke in half getting it out........
Bought a new one, all good.
Not hear to bad mouth anybody, I did it a warranty credit. Letting fellow members aware of a situation. I've never seen this happen before.
Old Aug 10, 2014 | 03:47 PM
lev's Avatar
lev
What brand?
That's why I prefer to clean the old one rather that buy a new aftermarket... Big problems with a lot of "new" parts out there!
Old Aug 12, 2014 | 12:44 PM
johnwilson1969's Avatar
I have had an aftermarket one split on me few years ago (after about a year of being on the car), I have heard others have as well. I replaced mine with genuine Volvo and haven't had any issue. Will definitely clean my OEM in the future.
Old Aug 12, 2014 | 06:56 PM
guest01's Avatar
Whatever IPD offers.
I purchased another one that said OEM volvo on it from a local reputable aftermarket and genuine oem wholesaler that deals with quality aftermarket parts. How is it even possible to clean without splitting it in half?
I noticed my t-stat dripping and pulled my voltage regulator just to see the height of the brushes and there's 2 more thing my "vo" needs............ Never ends.
Old Aug 15, 2014 | 12:48 PM
I purchased another one that said OEM volvo on it from a local reputable aftermarket and genuine oem wholesaler that deals with quality aftermarket parts. How is it even possible to clean without splitting it in half? .
Cleaner, air, shaking it like it owes you money.... seen a few youtube videos out there that show you how to do it.
Old Aug 15, 2014 | 08:59 PM
guest01's Avatar
....... I dunno how effective that would be. I pulled them apart and there's very heavy carbon.
Old Aug 16, 2014 | 10:29 AM
that suggests you have a lot of 'blow-by'
Old Aug 16, 2014 | 10:46 AM
lev's Avatar
lev
A very heavily plugged separator cannot be cleaned. But if it's not so bad, you can use something like long stiff wire to root in the holes to dislodge the deposits. Then soak it solvent and let it sit for a day. Then root it out again. The test is that air should move freely through it.
See this:
https://www.brickboard.com/FAQ/700-9...ion_A_Treatise
MC92
Aug 18, 2010 10:03 AM
spankey
Apr 22, 2009 08:48 PM
RRTEC
Jan 18, 2009 05:22 PM
