Opinions please - on IPD's Lubromoly
Old Aug 25, 2015 | 10:13 PM
Moetheshmoe's Avatar
Default Opinions please - on IPD's Lubromoly
Anybody try this stuff? - especially engine builders? Additives have been around for a long time and there's tons to choose from. But since IPD endorses it I thought I might give it a try. I have a great turbo L block engine with 167,000 miles and 165 lbs of compression in each cylinder. But when it first starts it has some valve chatter. Only lasts a few seconds till oil gets up there, then very quiet. I don't think it's piston slap because it doesn't need to warm up to quiet down. I thought this stuff might help or even a thinner oil that could get up there quicker? It has 20-50w right now.
http://www.ipdusa.com/products/5567/...ment-300ml-can
Old Aug 26, 2015 | 07:28 PM
lev's Avatar
lev
Oil in b230 is an overrated concern as the motor is the last thing to go in these cars!
I use full syn 10-30, change it every 5-6,000. Oil is the last thing I worry about; make sure you change the tranny fluid every 30k, and never overheat the engine--much more important!
Old Aug 26, 2015 | 10:01 PM
I understand in the US the word "synthetic" on some oils is legally over used(not true or full synthetics). What brand do you recommend?
Old Aug 28, 2015 | 02:28 AM
lev's Avatar
lev
I use whatever is the cheapest full synthetic I can find. Actually Walmart has great deals on oils.
Old Aug 31, 2015 | 10:21 PM
Thanks for the tip. I got 5 qts of Full synthetic at Walmart for $18.00/great deal. What kind of tranny fluid do you use and do you drain the torque converter too?
Old Sep 1, 2015 | 01:07 PM
I have been using Castrol 'Multi-Import' dex-merc ATF.... you drain the main transmission pan (start with warm transmission, let drain for /hours/, put the plug back in and add as much ATF via a dipstick funnel as came out the bottom. Now, disconnect the top transmission cooler line at the radiator and hook a clear hose up pointing into a graduated catch jug, then start the car and let it idle in neutral.... for each quart that comes out the jug add another quart via the dipstick, repeat until the stuff coming out is clear fresh red ATF. shut off engine, button up cooler line, test drive til fully warmed up transmission, check level with engine idling, add more if its low.
Old Sep 1, 2015 | 07:59 PM
Sounds do able. Thanks
Old Sep 1, 2015 | 08:00 PM
Oh forgot to ask - do you ever pull the pan and replace any filters?
Old Sep 2, 2015 | 01:03 AM
the AW7x trannies just have a screen, there's no point in replacing it. its a good idea once in awhile to pull it out, inspect it and clean it.
Old Sep 2, 2015 | 01:29 PM
ok thanks
Skiesthelimit187
Aug 20, 2007 05:40 PM
fairchance
Nov 1, 2006 12:27 PM
volvoai
May 4, 2006 10:30 AM
Stefan
Mar 2, 2006 02:24 PM
volvobacon
Dec 13, 2005 12:44 PM
