Parking brake......?
Old Jan 3, 2015 | 09:05 PM
Goldie88's Avatar
Default Parking brake......?
Seems like the parking brake
is /has completely been stripped out of the car..
The lever is still in car.. but, from the cables back
is.... NADA.... not a single stitchen piece of hardware......
It would be nice to have one.......
What do you think?
THe cost is in parts to
reinstate a parking brake......???
And ..... on the backing plate of the
the rear brakes..... Could something
perhaps have/had broke(being why it was stripped out)?
that holds the Ebrake
shoes and hardware in place
Or is this just a case of a
rusted seized parking brake
"lets just dispose of it" perhaps?
Let me know what you think
THanks, G88
Old Jan 4, 2015 | 07:26 AM
jagtoes's Avatar
Don't know which year and model you have but you'll need more information to see what you want to do. Once you pull the rear wheels and take the calipers off you should be able to pull the rotors. The rear shoe brakes are now visible and based on what you see you can make a decision on what to do.
Old Jan 4, 2015 | 02:23 PM
Goldie88's Avatar
Sorry I didn't put in the post...
It is an 88 240 DL.
Behind the rotor is completely empty....
So it is the whole "kit n kabboodle"
Any ideas on cost......?
any ideas on why someone might strip it out?
theorizing.... something broken on the backing plate
that is maybe why it didn't get fixed????
How would the brakes sit in their????????
(pins and springs??? like a conventional drum brake?)
Thanks, G88
Old Jan 4, 2015 | 02:43 PM
TIPSP's Avatar
Got Boost?
Download all the Green books for your car.
200 Series | K-Jet.org
Very handy to have these.
Old Jan 4, 2015 | 09:53 PM
Goldie88's Avatar
Thanks!
Old Jan 4, 2015 | 11:47 PM
I suggest you find a 240 being parted out in a junk yard somewhere, and strip it of all the parts you need. if you try and buy everything new, A) some bits are likely NLA, and B) it will be stupid expensive.
also, I'd plan on new parking brake shoes, new rotors, and new brake pads, since shoes and the drum inside the rotor bed in together.... I like Brembo brand rotors, and Akebono brand brake pads. volvo brand parking brake shoes, as I doubt there are any alternatives.
Old Jan 12, 2015 | 08:43 AM
Goldie88's Avatar
Thanks for the suggestion....
I will look into the J yards....
Do you know off hand,
regarding this E-brake style
what model cars it can be found in
these models and the years this style ebrake
was in production in these models?
So models?
and length of time used in models?
THanks, G88
Old Jan 12, 2015 | 01:02 PM
some of the parts are common to most all 240/740/940 but others are probably specific to a narrower selection. answering your question would require spending hours with Vadis (parts catalog) building a parts list, then checking other year cars for the same parts.
Old Jan 23, 2015 | 09:45 PM
Goldie88's Avatar
Pierce,
You sortof answered this question I
am about to propose... In your post...
but, I will ask anyway the forum...
I have found a 89 740 sedan.....
and I would be looking at salvaging
the entire rear brake system....
For a 88 240..... sedan.....
I would be grabbing the parking
brake setup from soup to nuts.....
Possibly the rotors and calipers as well...
Does anyone out there in the forum
have encountered making a swap like
this and had good results with all the parts
transferring over from a 89 740 sedan to a 88 240 sedan?
Thanks, G88
Old Jan 23, 2015 | 10:13 PM
740's have mostly 15" wheels and 240's have 14" wheels, I don't know if the back brakes are completely compatible. there's some differences in the rear suspension, so the axles aren't interchangeable... 740 and 240 have different torque bars and trailing arm designs.
Old Jan 26, 2015 | 08:08 AM
Goldie88's Avatar
Good to know thanks!
Ill post, more If I
delve into this....
for the parts.
TimClifton
Jan 30, 2013 06:11 PM
Johnny Volvo
Jul 12, 2011 11:52 PM
Counselor828
May 18, 2009 09:58 PM
sghokie
Sep 26, 2006 01:35 AM
Mass850
Oct 13, 2005 09:37 PM
