parts to replace when getting a 240dl...?
Old Mar 2, 2012 | 07:43 PM
mishka's Avatar
Default parts to replace when getting a 240dl...?
hey ya'll new to the forum and new to the car! i was just wondering since these are old cars (1986) what are some items and parts and etc. to replace and fix right off the bat ? i just basically want to know what are mandatory things a person should replace and stuff when buying a used 240DL so it runs good..?
another question would be ( yes this is two parts sorry ) i want to take my car to the mechanic i ave a mechanic who specializes in old euro cars and stuff, what should i ask him to do/look at that could have problems. should i just tell him to look over the whole car and inspect it and see what things should be replaced and fixed or should i approach him in a different way?
thanks,
tommy G.
Old Mar 2, 2012 | 10:35 PM
Burn Stains's Avatar
Welcome to the forum, will you happen to be doing any of this work yourself, because some of it is silly easy if you have the time.
Get the basic's done, can't go wrong with that. Oil, spark plugs, plug wires, coolant, hoses, air filter... When was the TF last changed? Brake fluid?
You'll want to check the flame trap as well, make sure that and the oil trap is not clogged, as well as the PCV hoses.
Take off that preheater hose that goes to the intake box as well. It's aluminum I believe, or so it's dull metal coming from the exhaust manifold.
I would check the fluid in the rear differential as well.
Other than that, I would either replace the fuel pump relay, or have a good know spare around.
What's the mileage, timing belt should be done every 50,000. Hows the other belts?
Hove your guy look at the bushings and mounts, those could be replaced, as well as some key front suspension parts. Make sure that stuff is genuine Volvo as well. Forget URO and MEYLE stuff...
That's about all I can think of right now.
Old Mar 2, 2012 | 10:59 PM
mishka's Avatar
burn stains all the fluids were checked and up to date!, filters are up to date!, i have not checked the firetrap but was going to replace it either way, i didnt know there was a oil trap either should i replace that or just clean it ? i dont under stand what you mean by the preheater hose dont replace it or anyhting? do you mean to jus take it off and leave it off? The one thing that sticks out the most are the fuel injection WIRES, i saw a post just before of someone having a problem where they were worn out and so are mine nd i actually have the same problem as the person the engine does shake because of the wires ( having rips on the outer layer ) i cannot find anyhtign online that sells the fuel injection wires!!!
Old Mar 2, 2012 | 11:42 PM
Yeah, take the hose off of there, and seal the bottom intake hole(where you removed the hose) inside the air box. It is this guy.
Old Mar 4, 2012 | 01:57 AM
Joseph/TX's Avatar
Read the product description for this item and you will see why Burn Stains wants you to toss the pre-heat hose:
Airbox Thermostat Valve (scroll down a bit)
Replacing the flame trap is essential; only Volvo uses this silly device, and if it get's plugged completely you won't like the result. (Blown seals, oil all over the engine compartment, possible engine damage)
Replacing the timing belt is also an excellent idea unless you know for sure when it was done last and it's gonna be hard to tell unless you have one of those rare 240s with a working odometer. You're not dealing with an interference engine so if it breaks you won't bend the valves, but it will definitely strand you. IMHO, these should be near the top of your to-do list.
Old Mar 4, 2012 | 06:58 PM
mishka's Avatar
what would i use than to cover up the hole to the air box ? is it really a big deal if i just leave it there ?
Old Mar 4, 2012 | 07:50 PM
Tape, fast and easy way. You could just leave it open, but it goes right under the car, so that could invite unwanted junk.
Old Mar 4, 2012 | 08:06 PM
mishka's Avatar
burnstain, i understand that the hose hooks up to the air box but where does the other end hook up to ? half of mine is missing.....
Attached Thumbnails parts to replace when getting a 240dl...?-img_3141.jpg   parts to replace when getting a 240dl...?-img_4539.jpg
Old Mar 5, 2012 | 12:07 PM
Joseph/TX's Avatar
As Burnstains says, you could just leave it open. The pipe just routes air heated by the exhaust manifold to the airbox and you only really need that in arctic conditions. The inlet that you would be covering up is before the air filter, so there's no problem with unfiltered air getting in. If you tape it over, the air will get in through the main inlet, which is on the drivers side, somewhat higher up.
Old Mar 5, 2012 | 09:07 PM
neco223
Oct 7, 2017 11:48 PM
nimzo
Aug 22, 2010 10:47 PM
scrap88
Apr 7, 2010 09:23 PM
Priory_of_Scion
Feb 15, 2006 03:36 PM
