Power steering pump rebuilding and wrong fluid.
Old Jun 18, 2009 | 04:23 PM
Sofar.'s Avatar
Default Power steering pump rebuilding and wrong fluid.
My power steering has been whining a lot lately and the wheel occasionally shudders when I'm parking. I fear that soon the power steering may begin giving out on occasion like on my old pickup, rendering the wagon unparkable. I was reading my service manual looking for instructions on how to rebuild the power steering pump (I might also just buy a new one for a hundred bucks or so depending upon your advice) and I discovered that I'm not using the right fluid. My manual says my car needs type A automatic transmission fluid and on the one instance I needed to top off the fluid I just used STP power steering fluid, it's likely the last couple of owners did the same thing. Does that make a difference? Should I drain my power steering fluid and use type A automatic transmission fluid before I try rebuilding the pump? Is there a bleeder valve or a drain plug or something like that?
Old Jun 18, 2009 | 07:10 PM
tedv's Avatar
I'd try using the right fluid BUT at this stage I doubt it will make any difference. And I don't believe there is a drain, just undo a hose and the pump will pump it out... just don't run it dry too much. I'd get a used one from a junkyard... cheap.
Old Jun 19, 2009 | 07:34 AM
adub96's Avatar
Pick one up from the junkyard, I think one will run you 15 bucks. I use regular old power steering fluid in my car with no problems.
Old Jun 19, 2009 | 04:39 PM
Typhoon's Avatar
Nah, unlikely to damage anything. The worst you can do with the wrong fluid is cause a few small leaks due to too thin an oil.
It's just a very basic hydraulic system, pump to pressurise fluid and two power chambers plus assiciated return valves. It really doesn't care what sort of fluid is in there, as long as it contains no air or water.
Shuddering is often associted with pressure valve issues, so don't overlook the rack.
Regards, Andrew.
Dagaan
Aug 15, 2015 08:44 AM
katiejoyful
Dec 12, 2007 04:49 PM
jguerra3235
Mar 21, 2007 01:34 AM
J Telectro
Jan 10, 2007 09:25 AM
blase
Jul 21, 2005 09:44 PM
