Rear brakes
Old Nov 29, 2005 | 12:37 PM
bogart's Avatar
Default Rear brakes
Am a bit confused re rear discs/rotors. I was under the impression that all 940s had one of 2 types or rear disc/rotor one for multilink suspension of 265mm diameter, and one for standard suspension with a diameter of 281mm.
What I am looking at are a pair of genuine Volvo rear discs with a pattern as of multilink suspension ie actual disc/rotor is in centre of casting but it has a diameter of 281mm. I was expecting the disc/rotor t be on the edge of the casting. I obtained these extremely cheaply and they have Volvo part number 272301-0 or EMB 5927415.
Nowhere can I find reference to my pattern disc/rotor having a diameter of 281mm.
Old Nov 29, 2005 | 09:17 PM
Default RE: Rear brakes
If you have Volvo rotors they should be stamped on them.
If not then try to match them up and see if they are the same.
jcmartin
Feb 27, 2006 10:58 AM
m1964
Feb 24, 2006 12:24 AM
JonesyGT
Sep 17, 2005 03:41 PM
JimKW
Jul 4, 2005 12:19 PM
