rear main seal leak
Old Jun 23, 2013 | 09:31 AM
teamcons's Avatar
Default rear main seal leak
My '93 940 has what appears to be a rear main seal leak. Gasket was replaced July, 2003 @ 140,284 miles. Seemed fine for a while, problem returned. Now 201,000 miles regular leak. Have not used an additive....
?? Best approach and ballpark cost now of rear main seal replacement; in 2003 it was approx. $450.
Any suggestions
Old Jun 23, 2013 | 09:35 AM
lev's Avatar
lev
They "should" last longer but the quality of the seal used is the key, also skill in the installation is somewhat a factor.
You should still be able to get it done for $500.
Old Jun 23, 2013 | 09:39 AM
brickrunner's Avatar
Have you replaced or cleaned your PCV valve. If it is clogged it could be causing excessive crank case pressure which causes oil to leak through the engines seals.
Old Jun 23, 2013 | 09:51 AM
lev's Avatar
lev
Good point! Not only the flame trap (PCV) but also the "separator" should be looked at before going after the main seal...
simonw
Feb 4, 2012 11:38 PM
jaymangano
Aug 17, 2010 05:10 PM
oreng
Jul 20, 2010 03:22 AM
moneypitbrick
Oct 12, 2008 06:51 AM
erickfredrick
Apr 30, 2008 08:17 PM
