Red Block Era Air Conditioning
Old Dec 16, 2018 | 09:05 PM
volvoguy8306's Avatar
Smile Red Block Era Air Conditioning
Calling all Red Block Volvo owners still running original Volvo air conditioning: Either R-12 or R-134a. There’s a small pressure relief valve (Volvo 1323803/3522398) in the AC system, usually right front either just behind the bumper or below the radiator. Mine appears to be leaking and, as of yet, I cannot find a replacement. After replacing the compressor and retro-fitting the refrigerant I’d like to continue using the AC system. Have you experienced problems with this valve?
What happened?
What did you do?
Have you found a source for this part?
Please share any experiences or references.
Old Dec 18, 2018 | 12:32 AM
lev's Avatar
lev
NLA new. Never had a problem with that valve, must not go bad often so should be available used...
Old Dec 18, 2018 | 07:08 AM
jagtoes's Avatar
When I did my AC system over this hose had a replacement without the valve in it. I believe you can still get the replacement. Just do a search on volvo ac hoses.
beleive
May 21, 2017 09:36 AM
mjohansson2
Aug 12, 2016 04:58 PM
Geogeek18
Jun 10, 2015 08:11 PM
schwalbe181
Jun 2, 2011 07:31 AM
jcmartin
Aug 16, 2005 12:28 AM
