Replacing a power steering pump.
Old Sep 26, 2011 | 01:06 PM
92_240_sedan's Avatar
Default Replacing a power steering pump.
So i have found a power steering pump with all the aux parts for a good price. It does not seem like a too daunting job so i am going to attempt it. One problem i have notice is i could not loosen the two bottom bolts on the AC compressor so i had to cut that belt off. Is there a way i can bypass the AC compressor and just run the power steering off the crank pulley?
any procedures i need to do before i attempt this?
my local dealer slash mechanic quoted me over 200 for JUST the pump and not the pulley or the tank or labor. found a 91 pump that should fit my 92 at a junk yard for 60 bucks.
Old Sep 26, 2011 | 02:13 PM
swiftjustice44's Avatar
91+ are all the same and the best pump IMO. If you look closely, you will see the ps belt will not line up with a pulley as is. You need to source an a/c delete kit. These were found on northern cars sold without a/c. Usually sell for $65-100 used.
Old Sep 26, 2011 | 03:33 PM
......... why is it so damn near impossible to loosen the ac compressor :/
Old Sep 26, 2011 | 03:53 PM
I'll go out on a limb and say because most so-called mechanics use an impact as a torque wrench.
Old Sep 26, 2011 | 04:04 PM
VileSmile's Avatar
Watch yourself with that AC compressor. The gas inside is under an extreme amount of pressure, and unless you are 100% sure it is empty, do not disconnect. You will burn, or kill yourself. I'm all for the 'do it yourself', but its a trivial piece of equipment.
Keep it safe
Old Sep 26, 2011 | 04:14 PM
im just trying to loosen it enough to slip a belt over it. i was able to loosen the bottom bolts. but yet it will only move like a couple of degrees.
Old Sep 26, 2011 | 07:49 PM
VileSmile's Avatar
As long as all the hoses stay intact, there is little danger.
Post some pictures
Old Sep 26, 2011 | 08:49 PM
Does anyone know what is keeping this compressor from moving enough to slip a belt over it?
Bolbo
Apr 13, 2012 07:16 PM
scrap88
Apr 7, 2010 09:23 PM
katiejoyful
Dec 12, 2007 04:49 PM
sod
Feb 24, 2005 11:53 PM
c70r
Dec 18, 2004 09:18 PM
