Salad shooters corvette wheels on 940?
Old May 13, 2022 | 07:13 PM
Alexey928's Avatar
Default Salad shooters corvette wheels on 940?
So my friend bought me a set of rims R16 8.5j and 9.5j, rear offset is +32mm. There is a lot of different information about tire size and spacers. What can you recommend?
25mm spacers will be enough? Full stock suspension
Old May 14, 2022 | 10:33 AM
lev's Avatar
lev
I'd recommend you sell them to a Corvette owner. Why ruin a 940?
Old May 15, 2022 | 07:26 PM
Are you asking about the spacers to use or whether a 9 inch rim can even fit in the rears.
The biggest size factory rim is a 7.5x17 ET18 running 225s, so if you are doing a 9 inch, you would be adding 3/4 of an inch to the inside and to the outside. If you look at the wheels you have you (probably a 6x15 ET 25) you can eye ball for available clearance. Note ET's are measured in mm so ET 25 means the rim's center line is 1 inch inboard from the face of the hub.
My guess is 9 inches is really pretty wide and wouldn't fit without some modifications to the fender lip.
My vote would be to pass on this offer as well.
twiin640
Jan 8, 2015 03:20 AM
tjohnson05
Mar 21, 2013 11:47 AM
92_940
Aug 5, 2011 10:22 PM
WalterXI
Jul 6, 2011 05:32 PM
turbo940v
Aug 27, 2010 09:42 AM
