seat heater switch
Old Jan 22, 2013 | 12:45 PM
morty1999's Avatar
Question seat heater switch
Hi guys,
The seat heater switch doesn't light up anymore on the driver's side (the passenger side switch still works), so I bought a replacement switch. However, I can't figure out how to switch them out. Any ideas?
Thanks!
Old Jan 22, 2013 | 04:13 PM
740wagonstlouis's Avatar
I got some from a salvage yard recently. They seem to pry up from the longer edge (side). Wire connection didnt pull out real far. Best of luck.
Old Jan 24, 2013 | 08:42 AM
lev's Avatar
lev
You have to remove the base where they sit: two screws under the brake handle, and the metal clip under the lip of the ashtray/fuse cover. Slide out the plastic piece under the brake handle too. Pull the whole thing out, much caution getting it from around the shifter; the switches are secured with plastic tabs, have to be removed from the underside. Careful with the old plastic, all those parts are prone to cracking!
ycartf
May 6, 2013 11:19 AM
Ryan Dunham
Mar 25, 2013 04:04 AM
mnvolvo
Mar 1, 2012 11:16 AM
stingman
2001-2013 model year V70
Feb 23, 2012 03:45 PM
panopticon
Mar 21, 2005 09:38 PM
