Several Leaks in my '91 940 turbo
Old Jan 26, 2012 | 08:34 PM
dmathews's Avatar
Default Several Leaks in my '91 940 turbo
I just had my oil changed and the technician told me I had a leak from my oil pan, transmission, and my rear differential. I'm wondering what I should do to find the leaks and repair them? Any advice would help.
Old Jan 27, 2012 | 11:10 PM
swiftjustice44's Avatar
Sounds like your lube tech already spotted them for you. It's an old car, they leak. And...the oil pan, transmission are the big three. If you are hiring your oil changes to be done, repairing the leaks may be a bit daunting. The oil pan leaks , generally, as a result of the oil pan gasket failing. The transmission leaks becasue of gaskets and seals failing...ditto the rear end. If you are not leaving enormous pools everywhere, I'd just monitor the fluid levels.
s80inWV
Jun 18, 2014 07:41 PM
ryama
Nov 17, 2007 11:43 AM
lordhowe
Aug 8, 2007 01:20 PM
Psaboic
Apr 29, 2007 03:12 PM
GrantXGoTerps
Dec 29, 2006 10:09 PM
