Shifter boot replacement
Old Feb 2, 2016 | 09:41 AM
Glidewide's Avatar
Default Shifter boot replacement
I need to replace the boot on the stick shift on my 1984 245 manual transmission. How do I get the boot on? Can I remove the reverse lock out mechanism and go over the top? If so, how do I remove it?
Old Feb 2, 2016 | 06:17 PM
lev's Avatar
lev
You mean remove the shift ****? You pulls straight out, it takes some force! Watch out for the O/D switch, wires, disconnect them carefully!
Old Feb 3, 2016 | 08:29 AM
Glidewide's Avatar
I will remove the shift **** and be careful when removing the OD switch, however below the shift **** there is a ring around the shift stick that moves up to allow the shift stick to go into reverse. Does the reverse lock out ring need to be removed to install a boot? If so, how? Will a boot fit over the ring?
Old Feb 3, 2016 | 04:35 PM
lev's Avatar
lev
What kind of boot are you using? The leather ones have a zipper, the rubber ones don't but may be you can stretch it enough to pass over the reverse lock out.
Old Feb 4, 2016 | 03:56 PM
Glidewide's Avatar
I have ordered a rubber one (did not know there was a leather option). I will try to stretch it over the reverse lock out ring. Perhaps it will work with the help of some lubricant and a something to pry with—a bit like mounting a tire. Thanks for the advice.
xDread92x
Jul 21, 2019 04:18 PM
ded137t5r
Jul 24, 2013 04:18 PM
kapka42
Dec 28, 2010 01:32 PM
rickderman
Nov 3, 2009 09:58 AM
0Trek0
Nov 9, 2005 11:42 PM
