Some questions on my 245 turbo
Old 07-29-2007 | 02:09 PM
Default RE: Some questions on my 245 turbo
Whats your screen name on Nasioc?
  #22
Old 07-29-2007 | 03:40 PM
ELD4AU6's Avatar
ORIGINAL: tech
ELD4AU6
Well I just got a autometer gauge like this one, and it fits in the stock location.
Its only boosting to about 2 1/2 psi[]
How much is a stock intercooled turbo 240 supposed to make?
  #23
Old 07-29-2007 | 08:33 PM
I would think atleast 8 Psi or so I would go to about 10 or 12.
  #24
Old 07-29-2007 | 11:28 PM
ELD4AU6's Avatar
under closer inspection
none of which were addressed in the ebay listing
http://cgi.ebay.com/ebaymotors/1985-...QQcmdZViewItem
yes i overpaid, yes im stupid for picking a car up at night[:@]
now on to looking for a 242
  #25
Old 07-30-2007 | 05:29 PM
That sucks!!!!
If you don't mind Pm me your Nasioc screen name.
I was going to see if the wife knew you.
  #26
Old 07-30-2007 | 08:55 PM
ELD4AU6's Avatar
ORIGINAL: tech
That sucks!!!!
its ELD4AU6
is your wife Subie Gal by any chance?
are any of these rust issues really anything to be worried about? I have a appointment monday at a bosch specialist that we take all of our cars to. Maybe he can diagnoise the 2.2psi, and the 10mpg[:@]
  #27
Old 07-31-2007 | 12:09 AM
Patdon10's Avatar
I can't help you with the turbo problem, because I just have the standard 245. I had the same glovebox problem though. First diagnose the problem. If you are able to (from a closed box) pull it open without turning the **** to open it, then you have a crack on the mechanism that holds in closed. open the box and look at what holds it closed. It looks like a little black circle and its most likely cracked. I just put a dab of crazy glue in there, and the glovebox holds tight again.
  #28
Old 07-31-2007 | 09:15 PM
ORIGINAL: ELD4AU6
ORIGINAL: tech
That sucks!!!!
its ELD4AU6
No she is rexygirl!!!
If the glove box isn't cracked what you might be able to od is heat the plastic up and pull it down a little. After time it warps then kind of shrinks. I have done that a few times and had good luck with it. Better than buying a new glovebox insert.
As for the rust when the floor starts sagging then I would worry. Try to get something done about the floor pan now before it gets much worse.
Lansdowne
09-22-2014 01:02 AM
Phil 850
07-25-2012 10:01 PM
felix96turbo
12-13-2010 07:43 PM
ibified
10-13-2010 09:11 AM
ryans89notch
09-15-2010 08:59 PM
Quick Reply: Some questions on my 245 turbo
