stalling warm start
stalling warm start
Having an issues where my '91 lh2.4 240 stalls on warm starts. I can keep it running by feathering the gas for about 15-20 seconds. After that it idles nice and smoothly. On cold starts it is able to stay running but idles fairly low, if i was guessing around 5-600rpm. No CEL
maybe your cold start injector isn't working?
maybe your idle air control valve isn't working?
a cold car should idle about 1000-1200 RPM, and a warmed up car 700-750 RPM. warmed up, with all accessories turned off, if you disconnect the IAC, it should idle about 600RPM (and any power accessories like A/C might stall it), with the IAC plugged in, that 700-750 RPM idle should be rock solid, and handle headlights, A/C and everything on full blast. and still idle 700-750 RPM.
I thought they had gotten rid of the cold start injectors by this point? I just purchased the car a couple of days ago so I probably need to give it a good once-over and clean the throttle body and make sure the iac valve is working and leak free.
deezgilliams (05-05-2020)
prophet_of_profit
07-29-2009 09:14 AM
