Straight though exhaust
Old Jun 13, 2010 | 11:11 AM
schwalbe181's Avatar
Default Straight though exhaust
i looked for this but couldnt find the exact answer. Does anyone run a straight thyrough exhaust from turbo to one muffler to tailpipe, no 2nd muffler, and no cat? Im thinking this would be more free flowing, and ME doesnt require emissions, and it also would be a throatier sound? Any advice?
Old Jun 13, 2010 | 03:01 PM
TIPSP's Avatar
Got Boost?
if you have no emissions, then do it. mine has a high flow cat, resonator, and muffler. it is fairly quite, and has a deeper note.
Old Jun 14, 2010 | 07:00 AM
adub96's Avatar
I had it, then I got rid of it. To loud and it got annoying after awhile.
Old Jun 14, 2010 | 01:40 PM
i have to replace my rear muffler and axel pipe, and possibly my front muffler. Im thinking of just running a straight pipe from front muffler if thats the cheapest. ANy other ideas? Turbo straight to muffler, then straight to end? No 2nd muffler or cat?
Old Jun 14, 2010 | 02:20 PM
TIPSP's Avatar
Got Boost?
That would be nice. do it.
Old Jun 14, 2010 | 05:45 PM
is it gonna cause a problem with back pressure for the turbo if i did turbo>straight pipe>muffler>straight pipe?
Old Jun 14, 2010 | 06:55 PM
TIPSP's Avatar
Got Boost?
no... you dont want back pressure on the turbine.
your turbo will thank you.
Old Jun 14, 2010 | 07:05 PM
alright im a noob to volvos and a n00b to turbos soo good to know
Old Jun 14, 2010 | 07:48 PM
TIPSP's Avatar
Got Boost?
are you doing the work yourself? or having a shop do it?
this is a good time to increase the diameter for better flow... if anything, I would start out with using 2.5" piping. this is a decent size, and is better then stock, which I believe is 2 1/4". if you plan to go further with the car, like bigger turbo, or tune it. 3" is what you want.
Old Jun 14, 2010 | 08:33 PM
ill be doing the work myself i can do all clamps, i dont have a welder. Is that possible? And im thinking of going up to 2.5" if ican. Can i just cut and fit and clamp it all togehter?
Old Jun 15, 2010 | 02:13 AM
TIPSP's Avatar
Got Boost?
you can. just make sure you check for leaks. the stock downpipe is 2.5" so if you cut up a little past the cat, it will bolt right up with the new clamps.
Old Jun 15, 2010 | 11:30 AM
solidd
Old Jun 15, 2010 | 12:52 PM
adub96's Avatar
i would recommend going to a shop. I had my whole exhaust done turbo back for 150 in 3 inch tubing.
Old Jun 15, 2010 | 09:17 PM
adub, was that with a new cat and mufflers? Or what did you have on it? Im bring it to a shop on friday to get the fluids changed, timing belt checked, and exhaust, maybe brakes, gotta see how long this will car before any work goes in it tho.
Old Jun 16, 2010 | 07:41 AM
adub96's Avatar
That was with a glass pack muffler no cat.
Old Jun 17, 2010 | 02:06 AM
redbottle's Avatar
you can solder before you place the clamp....buy a tub of everflux and plumbers solder, a mapp torch
put everflux on clean sanded ends with a small brush...just a light coat all around
fit together
apply flame to bottom of pipe connection
see the flux bubble and at the same time apply the solder on the sides
move flame to side and apply to bottom
same goes for the top of pipe
place clamp after...done
Old Jun 17, 2010 | 08:57 PM
  #17
alright, im taking it to a shop tomorrow for other questions and maitnance, so ill see how much he charges me, and that will decide it
creepingdeath94
May 29, 2010 05:26 PM
tmixdorf
Apr 11, 2010 11:17 AM
dmtri07
Mar 24, 2010 09:42 AM
Rangerphantom
Jul 22, 2009 07:21 AM
gr8gatzby
Aug 10, 2005 03:28 PM
