thread #4 on surging idle :)
Old Feb 23, 2015 | 08:26 AM
mcadek's Avatar
Default thread #4 on surging idle :)
this is now getting to be almost funny, can I bother you all one more time for ideas?
This is a video of the issue:
I didn't rev it in there, but it chokes around 2-2500rpms , I can't drive it at all, it just has no power to even go up the hill, backfires (my guess is through intake not exhaust) etc... As much as I wish this was idle related only, it is not, it affects the entire rpm range
the car is loud due to no muffler at the moment, but that's unrelated to the issue as the muffler has been off for months.
all new ignition parts, plugs,wires,coil,cap,rotor,new in-tank fuel pump, checked fuel pressure that seems fine, vacuum is jumping but so are RPMs, I checked for vacuum leaks everywhere even used a smoke machine which found few more little ones but nothing helped, I tried another MAF, cleaned grounds for injectors, redid wire connections on the coil... nothing helped
Could TPS do this?
Bad computer? by the way where is the computer on this car?
FPR? I think the FP was jumping 40-35psi or so, but I had a lousy gauge with a small leak, I sort of assumed that jump wouldn't matter all that much.
Only two codes were FI codes 113 and 232, I believe only 113 applies because 232 may have came on when I unplugged the MAF while the car ran.
IDK if this is a hint or not, but it tends to run for about 1 minute perfect when first started after sitting a while, then it goes into this surging idle crap.
Old Feb 23, 2015 | 09:46 AM
lev's Avatar
lev
Look at the Power Stage, a 3 inch metal plate looking thing with a plug with wires on the driver's side inside fender toward the front. Swap it with a known good one, see what happens.
Old Feb 23, 2015 | 11:09 AM
mcadek's Avatar
does it look like an ignition module? by the air filter housing?
I will make a junkyard trip, I'm done buying new parts for this thing, car isn't worth it overall with all the issues it needs, but I'll get one of those, TPS for good measure, I'll grab a set of injectors and FPR too. After that IDK anymore... lol
keep the suggestions coming pls
palebeachbum
Sep 28, 2010 05:50 PM
Tarheel Taxi
Nov 11, 2009 08:01 PM
outdoor7or24
Sep 17, 2008 09:26 AM
worldspeaker
Dec 23, 2006 02:07 AM
Richard74
Jul 22, 2006 12:39 AM
