Timing belt replacement
Old Jun 10, 2007 | 08:15 AM
oldvolvo's Avatar
Default Timing belt replacement
I've read a few posts about timing belt replacement that mention a special tool, which, I think, is supposed to immobilize the the crank shaft while removing the pulley. Is this necessary if you have an air impact wrench?
Also, I've seen mention of replacing the camshaft and crankshaft seals while doing this repair. Are the old seals difficult to remove?
Thanks for your help!
Bob
Old Jun 10, 2007 | 08:44 AM
oldvolvo's Avatar
Default RE: Timing belt replacement
Oops! Guess I should have mentioned that it's a 1989 240 DL Automatic.
04v70
Jul 17, 2009 11:01 AM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
