Timing belt replacement
Old Jun 22, 2015 | 09:54 AM
aznyaz's Avatar
Default Timing belt replacement
I am looking for any information having to do with timing belt replacement (i.e. tutorials, videos, text, etc.)
I have a 1991 240 and I will be replacing the water pump soon and wanted to see if there were any DIY links pertaining to the timing belt.
Thanks,
MJ
Old Jun 22, 2015 | 02:29 PM
fochs's Avatar
Good Pics:
https://oldcarjunkie.wordpress.com/2...g-belt-change/
Good info, download his pdf:
http://www.stepbystepvolvo.com/240%20timing%20belt.html
Old Jun 23, 2015 | 01:11 PM
aznyaz's Avatar
Thanks, again, fochs!
Old Jun 23, 2015 | 05:02 PM
fochs's Avatar
You're welcome!
goodluck
Old Jun 24, 2015 | 07:29 PM
dnarby's Avatar
Done about three of these so far.
Be sure to replace the tensioner pulley when you do the belt. These are typically included in a 'timing belt kit'.
Also, there's a little hole in the tensioner to put a pin in to hold it out of the way. An appropriately sized nail works nicely.
If you get it on and it runs strangely, you may be off by one tooth. Symptoms would be strong acceleration off the line, but poor high rev power, or vice versa. Had this happen when I had a cam installed (didn't want to do it myself) and the mechanic got it wrong by one tooth.
Old Jun 25, 2015 | 09:56 AM
REVOLV's Avatar
https://youtu.be/jVZ-DpDX1TQ
Old Jun 25, 2015 | 12:15 PM
aznyaz's Avatar
Thanks for the link. A lot of other good videos to find there!
04v70
Jul 17, 2009 11:01 AM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
