trans fluid leak
Old Feb 26, 2009 | 08:11 PM
lwrdr2's Avatar
Default trans fluid leak
1989 740GL wagon with an auto trans. It has a trans fluid leak. Im not sure if its coming from the pan gasket or someone said it might be the front seal. Havent crawled under to look at it yet but will this weekend. Is this a problem area that is prone to leaking and if it is a pain in the azz to replace?
Old Feb 27, 2009 | 09:40 AM
tedv's Avatar
Tranny leaks are ALWAYS a pain to fix unless it's the pan, or a loose line (you wish). The only way to find out, well, you know, get under there...
Old Feb 27, 2009 | 01:45 PM
lwrdr2's Avatar
Well i crawled under it and it looks to be the at the front of the trans. Maybe the front seal. Anynbody change it yet and goign to be a pain to do so or just take it in and have it done?
VolPat
Jun 15, 2012 08:06 PM
ded137t5r
Jun 10, 2012 07:40 PM
Eric's Hot Rod Shop
Jul 14, 2011 08:26 AM
volvolini
Apr 3, 2010 01:12 PM
VTBricked
Nov 21, 2009 07:50 AM
