Transmission swap?
Old Nov 28, 2007 | 12:49 AM
iamnickcarter's Avatar
Default Transmission swap?
I need a new transmission on my volvo. My four speed w/o overdrive isn't cutting it. I'm going to college soon in another state and taking my volvo on a long *** road trip for ~9 hours of driving at 3200+ rpms doesn't sound fun or healthy. Let alone, the milage!
My transmission has no problems and I just put a new clutch kit on, what are the chances of me swapping an overdrive unit into my '76 242? Should I just go to a junkyard and find a 'low' milage transmission with an overdrive on it?
Old Nov 29, 2007 | 12:52 AM
VolvoDriver's Avatar
Default RE: Transmission swap?
hello,
i do not understand what you are asking, could you re-phrase?
what are you looking for?
Old Nov 29, 2007 | 10:20 AM
Beardog's Avatar
He's thinking of swapping in a 5 speed or an automatic. Not sure which.
Old Nov 29, 2007 | 10:24 AM
Beardog's Avatar
@3200 rpm in top gear that means he's doing about 80 mph
Old Nov 29, 2007 | 12:56 PM
huh, if that's the case...what's wrong with the 4speed+5th OD? i imagine he has the M46...should suffice. if you wish to be more sure that it will hold out just replace the overdrive soleniods and wiring, and drain fluid and replace with quality lube.
Old Nov 29, 2007 | 10:46 PM
I said 4-speed without overdrive, I'm doing about 55 at ~3200RPM
It's crazy for my car.
I don't trust automatic transmissions and even more so worried about a volvo one.
I've got an m45 I think
Old Dec 1, 2007 | 01:21 AM
oh, ha...i neglected the 'w/o' part.
Old Dec 1, 2007 | 01:23 AM
if you can find an m46 in descent shape, have fun. you'll probably be very satisfied with the swap, if you go with manual transmission. you can get non-Volvo: getrag, world-class t5, yada yada. up to you and your fiscal assets.
Old Jun 16, 2010 | 10:59 PM
NightSailor's Avatar
Put an M-47 5 speed in there. And put a 3.31 rear axle in, if you don't have one already. That will give you 32 mpg on the highway if you keep it to 60mph.
Jklug527
Jan 21, 2009 04:57 PM
Jklug527
Jan 13, 2009 11:30 AM
alexm963
Sep 20, 2008 10:53 AM
cdalbon
Jul 16, 2008 01:12 PM
vcolper
Jan 29, 2008 07:47 PM
