Turn indicator and four-way not working
Old Jul 24, 2019 | 05:12 PM
Mistaciat's Avatar
Default Turn indicator and four-way not working
Hi,
I have a 1987 Volvo 240 station wagon, and have been having some issues with the turn indicators and four-way flashers. Namely, they don’t work. There’s no buzzing or any noise at all, just silence.
Ive checked all the fuses, the flasher relay, made sure power is running through everything, and I’ve tried putting in a new flasher relay but that didn’t fix anything either. I’ve been looking around for a solution and checked with a couple friends who’ve worked on 240s before but so far we’ve come up flat.
any ideas? Thank you.
Old Jul 24, 2019 | 11:18 PM
well, I'd find a wiring diagram, and start at the flasher relay socket with a volt meter, verify the pins that should have power do have power, verify that if you jump from the power in to the output signal, the turn signals come on, etc.
Old Jul 25, 2019 | 10:28 PM
xactorocker's Avatar
  • check your flasher relay as well
Old Jul 26, 2019 | 12:54 PM
Mistaciat's Avatar
Thank you everyone.
I've checked and everything has power, likewise the flasher relay. While trying to figure it out this afternoon, I turned the car on, flicked the turn indicators on, and both left and right started working (though the 4-way did not). Once I turned the car off, they stopped working. I tried this a few more times, though only succeeded in getting the indicators going on two of the attempts.
Old Jul 26, 2019 | 01:04 PM
sounds like the turn switch is fubar, then.
Old Jul 26, 2019 | 04:09 PM
Mistaciat's Avatar
I would think so as well, save that the switch still works for the hi-beams with no problems.
Old Jul 26, 2019 | 06:25 PM
but thats a whole different part of the switch and entirely different circuit
marc sanders
Aug 31, 2015 11:15 PM
RA082324
Dec 23, 2014 08:40 PM
spozag
Nov 29, 2014 02:55 PM
bihphaze
Aug 19, 2012 04:47 PM
WagHag
Jun 26, 2006 09:43 PM
