turn signals and hazard light not working
Old Aug 24, 2015 | 10:18 PM
marc sanders's Avatar
Default turn signals and hazard light not working
1997 850 t5. Problem with the turn signals and hazard lights not working intermittently. It is completely random. They will work normally for a while, then, usually after turning off the car and restarting, will not work at all. I have replaced the hazard switch and turn signal stalk without help. Any suggestions? Thanks.
Old Aug 26, 2015 | 05:58 PM
could be a connector or a balky relay or a bad ground. try pulling down the wiring diagrams to look for common junction points/relays/fuses in the circuit path.
Volvo Wiring Diagrams
Old Aug 31, 2015 | 11:15 PM
Thanks for your suggestions, and especially the wiring diagrams. They are much more clear than others I've had access to. I will check these things out.
pinkzambia
Nov 12, 2014 01:11 PM
Jonboy
2001-2013 model year V70
Apr 17, 2013 11:12 PM
efatsi
Mar 16, 2010 02:46 AM
Ked
Nov 9, 2009 09:27 PM
