Turn signals & other functions DEAD!
Old Jun 22, 2006 | 12:41 PM
  #21
WagHag's Avatar
Default RE: Turn signals & other functions DEAD!
Nah. There's nothing around the fan, and everything around the battery looks solid. I'm thinking that I may have some corrosion underneath the relay/fuse assembly, so I'm going to check the grounding plate when I get home today. It's a shot in the dark. The first time I removed the kick panel underneath the steering wheel, I was amazed. So many wires, so so many wires.
Old Jun 22, 2006 | 12:56 PM
  #22
WagHag's Avatar
Nah. There's nothing around the fan, and everything around the battery looks solid. There may be some corrosion underneath the relay/fuse assembly, so I'm going to check the grounding plate when I get home today. It's a shot in the dark. The first time I removed the kick panel underneath the steering wheel, I was amazed. So many wires, so so many wires.
Old Jun 26, 2006 | 09:43 PM
  #23
The A/C and Power windows are related they are tied together.
If the A/C compressor goes bad it will blow the A/C fuse and shut the windows down as well.
Maybe try to find a used turn signal switch.
Handysmurf
Jan 30, 2013 01:50 PM
mowntnbkr
Aug 26, 2011 08:12 PM
chellebelle393
Mar 5, 2011 12:36 PM
oddferkout
Sep 3, 2006 06:21 AM
