Volvo 240 5 speed transmission swap
Old Aug 27, 2015 | 12:45 PM
joshpo83's Avatar
Default Volvo 240 5 speed transmission swap
Hi I just bought my first Volvo it's a 92 240 sadan so far I like the car but the only drawback is its an automatic. I got it for such a good deal it was hard to pass up and at the junkyard I found a wagon 240 same body style and everything as mine but a 5 speed, what would I need to do the 5 speed swap and what would I have to modify? I'm just looking for a general parts list and recommendations for completing the swap
Old Aug 28, 2015 | 12:54 PM
at a minimum, you'll need the pedal assembly from under the dash with the clutch stuff, you'll need the transmission (duh), the flywheel off the manual engine (see * below), the drive shaft (different lengths), and the shifter+linkage. and the clutch itself, of course.
* if the donor car is a 89+, one less thing to worry about. otherwise, you'll need a flywheel from an 89+ manual 240, and you'll need to cut a notch into the bell housing for the crank position sensor. reason being, 1989+ 240's use LH2.4 fuel injection which uses a crank position sensor, while pre-89's were LH2.2 and used a hall sensor in the distributor for timing.
Old Feb 11, 2024 | 10:54 PM
junkyardvolvo's Avatar
14 years later I have a question; would there be any modification required when putting a newer m/t into an older car - like an m47 from an 89+ Lh 2.4 car into a 85 Lh 2.2 car?
onelly36
Sep 7, 2023 12:57 PM
onelly36
Aug 27, 2023 09:24 AM
Stephenstaly
Dec 17, 2020 01:57 PM
nebula
May 1, 2020 03:10 PM
hugostar
Jun 11, 2011 10:12 PM
