Volvo 240 PCV/Flame trap kit
Old Dec 23, 2017 | 04:19 PM
MrBric's Avatar
Default Volvo 240 PCV/Flame trap kit
How do i begin to replace the PCV and do the flame trap kit? also how does the PCV drain hose come out.
Old Dec 24, 2017 | 07:33 AM
silvermine's Avatar
this is a good source of info:
https://www.brickboard.com/FAQ/700-9...ion_A_Treatise
Old Jan 22, 2018 | 08:12 PM
Sleipnir's Avatar
(Deleted post - posted in wrong thread.
Old Jan 23, 2018 | 11:47 AM
modifierwong's Avatar
Just a correction...RWD bricks don't have (I think i'm correct on this one..) what you would typically call a "PCV". We have a combination of a flame trap and an oil separator. In most cases, you only need to replace the hoses and O-rings that get old and brittle...and clean the flame trap.
While you're at it, make sure you pull out the oil separator and change out all the O-rings associated with it. You can't physically see the o-rings, but these seal the oil separator to the engine block. You just might find out you had a vacuum leak that you never knew existed.
That link above has all the info you need.
Old Jun 28, 2022 | 12:02 PM
louella's Avatar
Default oil trap
I xc70 I had to remove manifold, removed fuel line, removed old trap discovered it was really caked up with carbon, also had too drop sump, the tube from sump was blocked, cleared tube, reassembled with new trap, parts bought FCP Euro, good luck
Forsyth
Nov 6, 2011 03:01 PM
KG240
Jan 18, 2010 04:01 PM
Volvo850GuyInMa
Nov 2, 2007 04:12 AM
Beardog
Jul 1, 2007 12:46 PM
HotCoil
Mar 20, 2007 07:20 PM
